2m AC12 Cable Weight?
What is the exact weight of a 2m AC12 Power Cable?
I was thinking this might be one metric by which to tell fakes from the real ones.
It is and it has been discussed here. The search function is your friend.
Paul has stated in the past:
‘It’s not a definitive test and we don’t recommend using weight as a guide. The best way is to purchase from us or an authorized dealer.’
Plus if they posted the weight, the fakers would just make the fakes match that weight. If it seems too good to be true, it probably is.
