2x TP-LINK MC200CM Gigabit Media Converter,
I have a long ethernet run from my computer room to my living room where the audio equipment is. I want to use the TP-LINK between router and switch to knock out line noise but the Directstream Jr. doesn’t pull an IP address when I do that. Both the NAS and Sonic Transporter i5 pulls an IP address. Unplug the TP-LINK and the Directstream jr. pulls an IP address. Running updated Bridge and Redcloud. All network equipment on the audio side is plugged into a Netgear switch…thanks…dl
Have you thought about trying one of the TP Link wi-fi extenders instead. I use this one with the DS and it works like a charm. There are models above and below it plus if you get it from Amazon you have 30 days to try it out.
https://www.amazon.com/TP-Link-Extender-Ethernet-Streaming-RE450/dp/B010S6SG3S/ref=sr_1_4?s=pc&ie=UTF8&qid=1514486795&sr=1-4&keywords=tp+link+wifi+extender
Chris at CA tested and recommended the model above mine.
dawkinsj said Chris at CA tested and recommended the model above mine.
The RE650?
Yes, that’s it.
https://www.computeraudiophile.com/ca/bits-and-bytes/extending-a-network-for-hifi-r653/
