About to buy SC Premier, can anyone help me to check it out?
Im about to buy SC Premier, its very rare ans scarce in my country, Malaysia. However I’m worry about counterfeit.
I have posted 2 pictures, can anyone spot its real or fake? Its very stiff.
1
2
There’s really no way to tell without cutting it open and then, of course, it’s not worth much.
Paul McGowan said There's really no way to tell without cutting it open and then, of course, it's not worth much.
Why its not worth much? I don't get it. I really want to try PS Audio Power Cord, but too many fakes circulating on the market makes it very hard to obtain one :( .
Thanks for the reply
Paul means that you cannot tell if the cord is fake unless you cut it apart. But if you do, you ruin the cable and, at this point, the cable is no longer worth anything.
