These so called “UltraHD 32” discs were mastered by Winston Ma and considered by some to be among the best sounding versions of the usual suspects. I was never able to play them on my PST or my new PMG SACD, and there are some that won’t even play on my Oppo 105D hooked up to my TV. In all cases each of these machines reacts as though no disc had been inserted. My LG multi-format computer drive, a $30 bit of nothing, can read these discs with no issue, so having ripped them to my NAS using this drive, that’s how I listen to them. Anyone else have issues with the UltraHD 32 discs?
yup, I don’t have any of it! could not afford them!
that’s my problem, I am poor now!
I don’t have any UltraHD 32 discs but (after all) they are just standard red book 16-bit 44.1kHz CDs, so unless they are defective they should play like any other CD.
You’d think so!
Tony, do any of them play on the 105D? I was under the impression the Oppo was limited to a max bit depth of 24 not 32.
No, but as Bruce pointed out when all’s said and done it’s a 16/44.1 CD. The 32/192 was used during mastering.
Got it, thanks. ![]()
