Anyone using Paul's Maestro Music management system?
Well, remember that Maestro sounds better than the others not because I am doing something special, but because I am NOT doing something special—I am purposefully leaving the stream in it untouched state after unpacking. So I can’t unmolest it further.
But that doesn’t stop you from trying, does it! :wink:
You never know where the road leads you.
Less is more thanks to Paul
Hi Paul I don’t get this, Maestro doesn’t unpack anyway? Grtz Jessy
Yes, it unpacks it.
Following Paul’s philosophy, I’ve been tweaking my setup for weeks.
I’m now playing music from my Mac mini M4 using Maestro via UPnP to a WiiM Bridge, then via Toslink to my DAC. The DAC is powered by an LHY battery power supply.
I was getting frustrated because Qobuz sounded absolutely beautiful, while my local music seemed to have a kind of noise in the background. My FLAC library was stored on an external SSD connected to my Mac mini via USB.
After doing a lot of reading and following Paul’s philosophy and beliefs, I decided to move my entire FLAC library to the internal SSD of my Mac mini. All USB connections are now gone, including the external SSD.
And what a difference! The sound suddenly became incredibly open, just like Qobuz.
I just wanted to share this. I’ve read that USB noise (the SSD also draws power) can contribute to increased jitter, potentially affecting how the music sounds. I can only describe it as a kind of noise in the sound itself… it’s difficult to explain properly.
Wow, wow, what a difference! I still can’t believe that this one change could make such a noticeable difference.
This is yet another confirmation of the theory Paul shares and advocates every day.
Musical greetings,
Jessy
I also like the SQ better from internal 8TB SSD of MU2 after moving files from an external SSD (4 TB Samsung T7). But I am using Roon, not Maestro.
I want to signup Maestro again when the tablet version is ready. I was on Maestro 200+ versions ago and have not tried it since. As of now it is too much trouble to control it from PC that is not near my system. Also, I still enjoy Tidal as much as Qobuz when streaming.
I prefer drives in an external caddy with linear power supply. I tried internal sata drives with linear power and there’s not a big difference. IMO The power supply is important.
I updated to 11.0.347. I noticed there are no release notes and all the previous notes are missing too.
:eyes:
Does anyone know how to bulk update metadata tags to multiple albums using Maestro?
I have many albums that appear in Maestro like “The Beatles” instead of “Beatles, The”. I notice this happens when the artist tag is populated with “Beatles, The” but the album_artist tag is null.
I’ve been reading about Maestro for some time and am considering trying it. I have no local file library and just use qobuz. I have a Windows 10 PC (yeah, getting pretty crusty), but no practical way to hard wire a connection to my cable modem/router. It’s about 30 feet away, but with no walls in between. I get good signal strength at my PC and about 190 Mbps bandwidth. I have a DSD Mk I with Bridge 2.
Q: I’ll need a WiFi to Ethernet adapter, but will this work reliably?
Many thanks!
You can bulk update any tag entry, or cover, on all the tracks (files) in a given album (folder) with Mp3Tag. Works on WAV, FLAC, MP3, etc. It’s free.
There’s no need to have an ethernet connection from your Windows 10 PC to the network. I often use wifi with my laptop and it works and sounds just as good as my wired PC. You do of course need your Bridge II wired as you no doubt already know.
Paul, for 356, had to whitelist into asus router reference to maestro api (for version about 10 days ago, didn’t need this, so thought your plan to remove the whitelist need had been accomplished)
Now that Maestro has progressed so far, I mention again my wish…that the left sidebar remain open rather than requiring pressing the 3 bars on top left of UI. I bounce around track to track and still must reopen this sidebar for each new track.
