Audiophile switch
#1
Just received my custom made audiophile switch. An HP 1810 modified switch was made for me by Pink Faun (http://www.pinkfaun.nl/portal/) for approx. 950 euro.
The following mods were made:
  • metal casing with isolation feet
  • a heavy passive regulated power supply unit
  • a Pink Faun power cable
  • a rhodium fuse
  • a Furutech IEC connectors
#2
adriaan said Just received my custom made audiophile switch. An HP 1810 modified switch was made for me by Pink Faun (http://www.pinkfaun.nl/portal/) for approx. 950 euro.
  • a rhodium fuse
Interesting.
I reckon that for this price the HP 1810-8G v2 Switch (J9802A) is included?
Do you have a picture of the rear side?
#3
The price of the 1810-8G v2 Switch (your own choice) is not included. You can choose your own switch.
The back of the casing:
#4
adriaan said The price of the 1810-8G v2 Switch (your own choice) is not included. You can choose your own switch.
Thanks.
I found these alternatives, however I am not sure if none of them are EOL:
http://www8.hp.com/no/no/products/networking-switches/product-detail.html?oid=5257664&jumpid=reg_r1002_nono_c-001_title_r0002#!tab=features
http://www8.hp.com/no/no/products/networking-switches/product-detail.html?oid=5304941&jumpid=oc_r1002_nono_c-001_r0002#!tab=features
http://www8.hp.com/no/no/products/networking-switches/product-detail.html?oid=5304935&jumpid=oc_r1002_nono_c-001_r0004#!tab=features
http://www8.hp.com/no/no/products/networking-switches/product-detail.html?oid=5096948&jumpid=oc_r1002_nono_c-001_r0007#!tab=features
http://h17007.www1.hp.com/us/en/networking/products/switches/switch-selector.aspx#.U3Pk9doaySP
My search was primarily filtered on smart/full management, GB copper, 8 port without PoE and fanless from HP.
I also would like to avoid a wall wart.
I think none of these are metallic housing.
#5
Wow sure hope you hear difference with your $1400.00 switch…
#6
These switches are a bit cheaper on eBay: HP 1810-8G v2 switch on eBay Suitable metal cases can be bought in DIY shops (rather cheap). That leaves only the linear power supply.
I have a 24-port version which is a bit more expensive, but it’s got a metal case already: HP 1810-8G v2 switch on eBay However it’s got a built-in power supply.
#7
The difference in sound quality using my audiophile switch is most apparent with high resolution (PCM 24) recordings. I am also going to buy a audio PC with linear PSU and (very short) high end Audioquest network cables.
The big question of course is: is USB streaming better than / worse than network streaming? I don’t know…
#8
How about building one that also encompass your router (with external antennas)?
#9
I don’t use my ADSL router anymore for my audio streaming. My PC streams to the audiophile switch and from there the network frames are layer 2 switched to the PS Audio Bridge.
