BHK Preamp screen fading
The letters in front screen of my BHK Preamp have been fading for a couple of months. Is there anything I can do to correct this? Thanks in advance.
Sorry to hear that! My BHK pre is about 3 years old. To preserve the display, I developed the habit of turning the display off whenever it’s in use.
Sorry to hear about the fading screen. You would need to talk to someone at PSA to replace the front panel. I don’t think the display in BHK is LED and it shouldn’t cost too much to replace it. Like Serhan, I turn the front off if I play more than a few hours.
You should also check the screen brightness setting. I’m not sure if the manual even mentions it but there are three choices: bright, normal and dim. You get to them by pressing the small black button for a couple seconds and then cycling through the settings options until you get to screen brightness.
Screen brightness setting checked. The display still shows the same defects as before… Thanks for trying to help.
Did you have your screen replaced?
No, I haven’t decided to do it yet. It’s hard to be without music for a week or more…
When I had to send my BHK Preamp For service I plug the cables from the DAC into the cables feeding the power amp and I still had music. This is the advantage of running balanced cables. No need to deal with feeding cables around the rack!
Good idea. Thanks!
