Bit Perfect Test
#1
I ran the test tonight but did not get the green, does the player need to do DSD ? Using Amarra which doesn’t yet.
#2
rogerdn said I ran the test tonight but did not get the green, does the player need to do DSD ? Using Amarra which doesn't yet.
No, the test is 24/96k PCM, it should run on almost any software and thru any DS input.
Someone else might have an idea what it takes to get Amarra (or the OS) bitperfect.
A quick and dirty test is if ripped CDs show 44.1/16… If instead the sample rate is wrong, you have some sample rate conversions going on and if the sample width is wrong you probably have some volume control (or replay gain) happening.
#3
Thks Ted, No my cd rips show 44/16. Can ask Amarra, but no idea what kind of Mac OS problems might be involved
