Bridge Update
Hi
I have a direct stream which is connected to a Intel NUC based Roon server. The connection is USB.
I can’t seem to update the Bridge software. It’s stuck at 1.25. I know I how to do as in select bridge output then go into the menus to check for updates. Even though I use the USB and everything runs fine, this bothers me.
Is there and way to force the update or any other way to do this. The direct stream is running Snowmass V2.
Thanks
I would suggest trying to do the update via mcontrol app. I couldn’t get the bridge update to work on my DSJ (via menu) but it worked perfect via mcontrol.
