Can’t login
For some reason I can’t login on my PC today
It’s happened before but there was a choice of emailing me a login link.
This time the only option is to login with a USB key. Strange.
I did clear the cache and try 2 different browsers but no go.
Using my phone works fine but is a PITA.
Any ideas?
If you were able to log in using an Internet USB Key it could depend on your IP.
I did not have a USB key and have no idea why they would ask for one in a login page.
Thanks!
it could be a service failing to start. try booting in safe mode
I’ll give it a try later today.
Thanks!
I ended up doing a complete shut down and restart (instead of reboot)and that did the trick.
I should have thought about this as it is advice I often give others that have similar computer glitches
Glad you got it working :slight_smile:
Thanks!
Dang computers anyway.
