Command line parameters of Windows USB Install to NOT check for power
I have an extra windows laptop I want to use for either A+ or Aramma to my SGCD, but when I run the PS Audio USB install, I get an error that I need to have the laptop plugged in. It is plugged in, but the installer must be calling an API on my machine that is failing OR the pin in the plug is not working.
Anyways, is there a command line parameter for setup.exe that would NOT do that check?
