Computer can't see DAC
#1
I have connected the usb cable and ensured the usb port is working. When I try and install the driver, it can’t see the dac. I have tried 3 usb cables and tried 2 different pcs with the same result each time. Coaxial connection works fine but I bought this device to use the usb input. Can someone please advise?
#2
Clsmooth391 said I have connected the usb cable and ensured the usb port is working. When I try and install the driver, it can't see the dac. I have tried 3 usb cables and tried 2 different pcs with the same result each time. Coaxial connection works fine but I bought this device to use the usb input. Can someone please advise?
Howdy. A bit more information will get things moving. What operating system are you using in your computer? Which PS Audio DAC are we talking about? Is the DAC new?
With USB, I often find the computer needs a reboot after it is connected to the DAC to enable it to discover the DAC.
#3
good suggestion above.
I would add that removing the USB cable before rebooting PC and DAC might also help.
After everybody wakes up, connect the DAC LAST.
#4
Thank you so much for that, it worked. I had initially plugged it into a USB hub where I knew the ports were working. A friend suggested plugging it direct to the PC so I tried that and had the same problem, even after re-booting the PC. I turned the DAC (PWD mk2 upgraded from mk1) off and on from the back and it has now picked it up and works perfectly. What’s really strange is that I had the same issue on a laptop where it wasn’t recognized. The OS on both is Windows 7.
#5
good to hear it is working.
It is an old windows USB trick to cycle the PC WITHOUT the cable and then plug it back in to create a FRESH discovery. PWD seems to like it too.
Enjoy the Music.
G
#6
I turned the unit off from the back for about 30 mins just to make sure that everything is fine. When I turned it back on again, Windows couldn’t see the DAC. I spoke to PS Audio and the unit has to go back as it seems to have a fault. I happen to be going overseas for a month and that’s how long repair, testing and two way shipping should take so not bad timing.
#7
Just in case. Sometimes removing all USB drivers helps. Windows will reinstall them when needed.
Or just use Linux :D
