dac nuwave dsd
bonjour comment lire des fichier dsd et 24 bits avec le logiciel elyric de ps audio je n arrive qu a lire des fichier 16 bits 44.1 khz
merci
Welcome, David
I do not know if eLyric is still supported. I also never used it and do not know how to play DSD and 24-bit files. If I understand your post correctly, they are both displayed as 44.1/16 files when you try to play them. I hope someone here can help you.
Sorry but PS Audio stopped supporting eLyric quite some time ago, long before DSD became common. It might be possible to use another program to convert DSD files to DoP files that appear to eLyric to be PCM files.
