Dealing with bass-heavy recordings
mike48 said I won't get into arguing with those who claim the cure is worse than the disease. I can only assume they are looking for different things in sound than I am.
I was only addressing your claim "If the tone controls are digital, there’s no loss at all." This is incorrect.
I am glad you are delighted with the processing you use.
mike48 said
I suggest you read all the rave reviews of Sigtech, Devialet, DEQX, miniDSP, Holm, Lyngdorf, and TacT equipment that corrects in-room response.
There is an ART graphic equalizer on Amazon that a fussy audiophile friend recommends. It’s less than $200. It would be a relatively cheap way to find out if EQ might be for you. A fancier option would be an Accuphase DG-58 for about $8k.
Thank you for these recommendations; I have a lot to learn about this stuff.
But to correct the deep bass, an electronic approach is a necessity. You just can't do it practically with conventional bass traps.
I do know that bass traps don't absorb much below 70-80Hz, but I think I can get closer to where I want to be with some additional traps. We'll find out. The ART unit you mention might be a logical next step if the acoustic treatments just don't make it.
I was only addressing your claim “If the tone controls are digital, there’s no loss at all.” This is incorrect.
Elk, of course you are right. “No loss at all” was an exaggeration. I have found, though, that in the bass especially, the improvement typically far outweighs any loss. And higher up, even minimum-phase digital filters can sound quite good when one keeps the Q low and the boost or cut not too large either. I have a digital EQ unit arriving soon with linear-phase filters – said to sound more natural – and I’m eager to hear how it lives up to its billing.
The approach I have taken is first, adjust speaker and listening positions; second, treat the room; third, EQ if one must. I find such variation in frequency response among recordings that even given good acoustics, a system with tone controls – engaged only when needed – increases my enjoyment a lot.
Mike
mike48 said I have a digital EQ unit arriving soon with linear-phase filters -- said to sound more natural -- and I'm eager to hear how it lives up to its billing.
It should. What unit are you getting?
A good approach. :)
A good approach. :slight_smile:
Thanks!
It’s a Weiss EQ1-LP Mk2. I found it used on eBay.
By the way, the most costly component in my system was the room itself. I designed it and had it built in our basement, with soundproofing to keep out the HVAC noise. The second most costly was the acoustic treatment, if I lump the costs of all panels, bass traps, etc. (About half of those were bought ~10 yr ago for my old location.) So I do practice what I preach!
For classical music, let’s quote this strange recording of Carmina Burana cond. by M Tilson Thomas.
I know both the score and the very most (commercial) recordings of the work, and this one is very particular for overemphasizing the low bass range. Doublebasses, drums… A rumbling that is quite disturbing because it quasi-constantly weightens the soudstage.
Actually, whatever the works (choirs, symphonies…) I know no other recording as deep and heavy as this one. Quite un-natural.
All the more, some moments are very impressive in the extreme low register.
Try Olim lacus colueram (track 13), 1’56-2’01. Not loud, but so deep and powerful (a sudden and incredible boost in the 20-50 Hz range, for a few seconds, according to my equalizer), as to really shake the walls. I first believed it was a earthquake!!!
Mostly for propulsion IMO
made me smirk :wink:
still - an eq is a fun tool for anyone to play with, as long as it spends most of its time in bypass mode the risk of “addiction”* can be avoided.
* addiction is a serious health problem and should not be minimised, i just can’t think of a better analogy apart from maybe sugar in tea :slight_smile:
I’m just playing this CD. That must be a monster bass drum in track 13.
I’ve a large room and don’t consider things to be out of proportion (at least not what I’ve heard so far).
