Direct Stream Bridge Update
Hi I have recently switched from a DsJ to the big brother. I have updated the firmware to Red Cloud but the bridge is not showing up. When I go to bridge it shows 1.21 as the latest installed. Any way I can force the update?
Thanks
Sorry I meant the Bridge update. Mine shows 1.21 installed and up to date. Everything else works fine. I am listening to my own music as well as streaming Tidal all done through Roon.
I think there is a bug where it won’t show an available Bridge update if you have the SD card plugged in in the back. If you remove it and do a reboot it should then show up after a few minutes (does for me and others anyway)
