DirectStream DAC noise
I want to hear if it’s normal that it’s noise when I change phase on the remote control.
Is it a smart way I can get it gone or should I live with it?
Thank you for your good support.
More love from Denmarkgoofy-heart_gif
Michael
Hi Michael,
Thanks for reaching out to us about your issue.
Please contact us at service@psaudio.com and we’ll be happy to get you assistance.
  • Jeremy
If you are talking about a pop or click then it's expected - unless you happen to catch a signal going thru zero you'll get a one sample transition from one polarity to the other.
If there’s anything more than a single pop/click then there’s something else going on.
It is within the normal that Ted writes about. Thank you for your support.
