Directstream quit after installing P5
A couple of days after installing P5 (which made great improvements with my system BTW), my DS turned itself off in the middle of a song. Nothing else turned off. I rebooted the DS and it worked fine for another few hours then turned itself off again. Again I was able to reboot and get it functioning properly. This am I turned DS on from standby and played a file from Roon, but no output from DS. Display shows it detects file from server and is using the proper connection AES/EBU, but no sound. Connections are good, system will play vinyl, unit is not muted. I’ve contacted support, but wondering if anyone else has experienced same.
Thanks,
Steve
Does the DirectStream play from other sources/inputs?
I would install a previous firmware and reinstall the firmware you are currently using. It may have become corrupted.
