DL II Power Supply
The separate power supply to my long time friend Digital Link Generation 2 has disappeared during a recent move. I’m going to assume you don’t have any extra ones laying around so I’m going to have to make or source out a replacement. Would you give me the specifications of what it takes. Volts DC, amps and such.
Thank You
Can you post or email me a picture of the unit so I can make sure I give you the right advice?
Thanks for your time. I tried to include board REV #s if that helps. Serial # IA1559.
Ahhh. Yes, well, I don’t have the documentation any longer but I looked inside the one we have and would feel comfortable with a 30vac transformer. Bigger amperage the better the sound.
