Document system setup easily
https://www.draw.io
Very easy to use Visio-like web based interface makes documenting your system quite easy. As time goes on, I tend to forget how I ended up where my system stands, a few minutes to document the changes helps a bunch months/years down the road.
Brett
2%20Channel
Much detail to still add but this only took 10 mins. to create from scratch
Nice, I like pictures better than paragraphs.
This is very slick.
