DS Jr. - problem with Snowmass update via Ethernet
How much time to update dsj to snowmass
through Ethernet connection. It’s been running for hours
Total time <10 minutes for me.
Thanks for your fast reply. I’ll try again.
I’m not a DSJ owner but my understanding is the firmware updates require downloading the files to the root level of a USB thumb drive (preferably a small one formatted in FAT) and that only the Bridge updates are directly over Ethernet/internet.
Please note that you cannot update via the Ethernet connection. You have to use a USB drive with the new firmware files on it.
More detailed info in this thread:
https://forum.psaudio.com/t/snowmass-directstream-junior-is-now-live
The ethernet port will only update the Bridge inside the DAC. As mentioned before, you need to use the USB port to update the DACs operating system.
