dan said
Why don't you try connecting your DS directly to your amp and power it down with the DS "muted," and tell us what you hear.;-)
I run the DS directly into a large tube amp currently, and previously into a solid state amp. I'll swap back, or use another amp in a bit as I like to continue changing and evaluating.
Mute on the DS nicely works as a mute and I use it regularly; the sounds stops coming out, and everything gets nice and quiet. Weird, huh?
The problem you are experiencing appears idiosyncratic to your choice of amp. Given the large number here who run the DS directly into an amp we would have heard of the issue long ago if it were a common problem.
dan said
Does the mute function on any other piece of audio gear on the planet function this way?
Yes, a number of products transmit and/or process digital black when muted or the volume is set to zero.
It is unfortunate you have experienced the problem. The good news the issue is rendered moot by your determination that another DAC sounds better to you.
I’m running direct to a Spectron solid state amp. No problems with mute, and it doesn’t seem to matter what order I turn things on or off… everything stays nice and quiet.
I’m glad to hear that the DS “mute function” works for others.
Put my other DAC back into my system, no noise when powering down when it’s muted, and there’s no hiss unmuted when I pause the digital input with my ear right up to my speakers.
With the DS there’s always a hiss coming from the speakers when I pause the digital input or hit the mute button.
I do not recall others complaining of a hiss and, of course, no one else has claimed problems with the mute function.
If you feel there is something wrong with your unit, I suggest disclosing this to potential buyers. Better yet, return it to PS Audio and let them take a look.
After talking with customer service and confirming how the DS mute function works, I don’t think there anything wrong with my DS, the hiss can’t be heard at the listening position.
I’ll bet anyone who has an amp with an input sensitivity of less than 1.5v, can hear the DS hiss with their ear close to their speaker.
This sounds like a ground issue to me. Perhaps with the DS- a bad ground inside or the USB tape ground, or somewhere else in your set up. Can you hear the hiss with the volume at zero (I do NOT mean with the volume muted)?
I too, have some hiss or noise being produced by the DS. I installed the kit in my Mark II two weeks ago. At first I thought it was tube noise, but then I realized it disappeared when the DS was turned off and my tube amp was left on. I hooked up a solid state amp and the noise was still there and the same character. It is very low in level and the DAC sounds very good. If other’s DSs are dead quiet however, perhaps I may have a problem and the performance of the DAC may be even better than I am hearing.
My amp is a Line Magnetics 518 integrated 845 SET rated at 200mv sensitivity (integrated). I am using the direct input though. But the noise is the same using the line stage or going direct. Speakers are Zu Def 4s rated at 101db sensitivity.
There is no hum, just soft noise with a periodic very soft electronic squeal. I connected the analog outs of my Oppo 103 player to the line stage and also the DS through the line stage. The Oppo has similar character noise but significantly lower in level, but not dead quiet. What has impressed me is how quiet my amp is. Thanks for your input Elk.
Your speakers would reveal every little thing. By the way, are they as wonderful as they say? I have read nothing but excellent things about them, but have no personal experienced with them.
So, you don’t think there is anything amiss with my DS, that the noise level is a compromise in the design that only shows up on very sensitive speakers? Hmm. In fairness I would say that the noise level would be within the bounds of acceptable from many a tube amp. Also, to return to topic, I might add that my mute works as it should.
The Zu speakers allow me to enjoy the glory of SET amp simplicity with the ability to go loud and low. They are an effective blend of compromises to my ear. I’ve heard them with a good range of amps and they sound best I think with the 845 tube. The first thing I played on them with a Sanders amp was Miles’ CD Milestones. After just the first cut I knew this was the way I wanted horns to sound and that was it. I just needed to find the right amp and I was pretty sure the Sanders was not it although it sounded excellent on the Dynaudio C-4s the Zus replaced.
I might add the DS is fed power from a P-10 through an AC-12.
