DS top plate
I purchased my DS as a demonstrator and the top plate is scratched. Is there something I could do to polish it out?
PaulCEO PS Audio
Feb '17
The tops are acrylic paint over HDF (wood). The process to get them looking that nice is extraordinary. They are painted, then polished on large buffing wheels in a series of finer and finer grits until the final polish which is done by hand. It’s about a twelve step process if I remember. In any case, as Frank suggests, you can treat it like any painted surface. Mostly, think of it as a car finish. It can be polished, waxed, even rubbing compound if it’s in bad shape.
Thank you
