DSD Kit Problem...Help!!!
Hello,
I just finished upgrading my PW II DAC (w/ Bridge II) to the DSD DAC. Everything seemed to go smoothly, I inserted the supplied SD card, and turned on the power.
The power light blinked for about 20 seconds and I go the initializing screen. But there’s no progress on the initializing progress bar. It just sits there.
I didn’t check the version of the Bridge software first. But I did update it about 6 weeks ago, so I’m pretty sure it’s up to date.
Also, I’ve removed the bridge and the results are the same…stuck on the initializing screen.
Thanks,
Steve
Okay…user error!
Steve
