DsJ using Tidal & MConnect
I am using Mconnect from both Android and IPad to render Tidal to the DsJ. How do I control the streaming rate? HiFi/Normal/High? I want to make sure I am streaming HiFi from Tidal.
Hifi would be the way to go as it is the “lossless” stream.
Thanks, Yes I want to make sure I am streaming HIFI… I dont know how to tell, or how to set it.
awlom said Thanks, Yes I want to make sure I am streaming HIFI... I dont know how to tell, or how to set it.
You don't set it inside mconnect. The HIFI mode is decided from your Tidal subscription type. When you log in with your credentials (first time) HIFI is what you get at long as your Tidal subscription is HIFI. Log on to their (Tidal) site and upgrade, accordingly.
Frode , thank you for your reply. I have the HiFi subscription…
Using Mcontrol (which I prefer over Mconnect, but seems basicly the same) you can change the streaming quality under settings in the tidal menu.
