When the volume is set to the maximum configured, despite the Menu View config, Sample Rate is always shown.
Does anyone else is getting this?
Ted, is it by design, or some strange behaviour?
I already gone back to Huron, and back to RedCloud, and I always can replicate the issue.
For instance, if I set the max volume to 98, and then select any value until 97 the Main View is what I defined on the Menu View option (Volume, Sample Rate, Bridge). But if I select 98, the select view is only shown for 2 secs and then Sample Rate.
I tried with different max volume configurations, and equal behaviour.
Thanks.
