DSJr Fuse Upgrade?
How does the DSJr’s fuse get accessed? The DSSr requires opening the case, but I’ve found nothing in these forums regarding tweaking the Jr.
And is there a go-to value replacement short of the beeswax fuse? I note that the HiFi Tuning Supreme 1A SB 5x20mm…I think that’s the correct size…can be had on sale for 15% of the organic fuses’ price.
Things are simpler when it comes to accessing the DSJ’s fuse. There is a fuse holder on the back near the AC inlet. A flat head screw driver can be used to open it. No need to open the case.
You are correct on the size - 5x20mm 1 amp slow blow is the way to go.
