Electrical flicker and then to 100% volume
Had a weird electrical thing happen this morning at our house. Our power flickered on/off 3-4 times in pretty quick succession, with each outage a bit longer than the one just before it. The whole event spanned about 5 seconds. And after the last flicker, it got scarey. FYI, I do have a surge protector.
Before this electrical flickering, I was listening to my StellarGold DAC + M700’s + Magnepan 1.7i’s + Rythmik sub at about 30 on the DAC’s volume indicator. During this power flickering event, the equipment stayed on, and after the last on/off flicker the volume of the DAC instantly changed to 100% and played at that volume for <5 seconds. Scared the crap out of me. I quickly jumped from my chair and hit the power buttons to turn off the DAC and amps, and unplugged the sub.
Why did the DAC volume get instantly changed to the maximum? Did this power flicker damage any of my equipment or speakers? Everything seems to function and sound fine afterwards.
When I checked the electrical panel, none of the breakers were tripped, and none of the clocks or appliances around the house got reset or were flashing like after a power outage.
What do you make of this?
Welcome!
Our power grid is an intricately, complicated, interconnected system. Lots of automatic systems to adapt to constantly changing systems. There are automated safety disconnect systems that repeatedly attempt reconnection. If you system has returned to normal, I wouldn’t worry. Sort of like needing to reboot your computer after a power outage.
Sounds like your DAC did a factory reset and the default afterwards happens to be fixed volume at 100%. Not good thing to happen but it sounds like your Maggies survived it okay?
My settings were preserved through the ordeal, and l guess at some point I had set the maximum volume to 75…thank goodness! Things seem to be fine. I have now inserted a CyberPower UPS inline.
