Eversolo DMP-A6 Master Edition
NIce, most certainly nice.
I never put my Fiio into my main system. I haven’t powered up my Fiio desktop unit in months. I should compare them.
The feature set and remote control app for the A6 sets the high bar. Sound wise I should compare them. The desktop Fiii unit is less than $700…
Yeah, the price difference isn’t enough to break it either way. The giant beautiful touchscreen on the Eversolo is something, but the Fiio looks great too. Thinking of adding it to my Asgard 2 for a headphone setup. Or on my main system as the streamer. So many options.
Thanks!!
Should I send mine to you?
Did Darko use the ES with an external DAC?
I think with the right DAC this thing is soooooo good. And I don’t have the brain cells or experience to explain why.
Not what I was asking for at all!! I was just curious based on your experience with both which you’d recommend.
Yes, I saw the Darko video reviews…I’m just not a fan of him at all. Which, I know, puts me in the minority.
Basically, I explicitly trust your takes on stuff here, so I thought I’d ask.
(Besides, @1cdfoley already told me I don’t need another streamer)
Different strokes. Would be interesting to know what you find off-putting.
I really like the guy. One of the few I find I watch all the way through.
Interestingly, I can’t relate to his taste in music at all.
I enjoy his work, but not his music, also.
Dunno. There was just something off-putting. Probably he’s European brusque while I’m Midwest-nice. It’s mostly probably just cultural. And, yes, I can’t stand his music.
That and he tends to do videos for reviews and such while I prefer to read the written word. It’s like audiobooks vs books. The only audiobooks I like are autobiography narrated by the author. I enjoyed Bryan Cranston’s book and adored Phil Collinsā€˜s. Otherwise I just can’t connect and finish having no idea what I just listened to.
Choices are always good.
I connected my FIIO portable device to my ML preamp on one occasion, listened to 2 songs, and decided that I will never do that again, and I love my portable FIIO into headphones.
This has been out for a couple of days, don’t know how I missed it. He has some interesting thoughts after installing his LHY.
well my LHY LPS arrived today and i installed it.
Was it easy to install?
Very.
Does it sound great?
Yes.
Can I tell a difference from before?
No.
But I didn’t break anything so I consider it a win.
EDIT: just seeing that video above… the guy says you’d see a bigger change if you use the internal DAC. A little less of a change if you used SPDIF out. Minuscule change if you went USB out. (Which I’m doing, into a Matrix X-SPDIF 2 then I2S to the Denafrips DAC.)
That checks out, I reckon.
I will say, tho, the thing sounds really really good.
Yeah the LHY ones is still relatively noisey. Probably had to cut some corners to make it fit. It’s not worth having linear power supply just to have a linear power supply. You want one that has almost zero noise.
it doesn’t sound noisy
i would not be surprised if it measured better than the stock one, but I can’t hear it.
or my system isn’t resolving enough
or both
I just installed mine, leaving it powered on for a bit. But my audio memory is not as good as others here and I have hard time telling small differences with things. Guess that is a good thing, keeps me out of rabbit holes.
Did you get your pardo mod installed?
Disregard. I see you have in a later post.
You usually don’t hear the noise, but you can tell when there’s a lack of noise with these kinds of mods.
But there is not a lack of noise on these forums :wink:
yah i was kinda kidding.
i didn’t hear noise with the original PS, and if the LHY has less noise, well…
seriously tho, i think it sounds absolutely fab.
I did upgrade the PS for the matrix xspdif 2 a bit before this, and could I tell a difference with that? Ahdunno.
My Teddy Pardo supply made a nice change to my A6. Having no power supply in the A6 makes a nice change no matter what @CoolZero says or believes.
