Forum just went wonky
Perfect! Thank-you.
One thing, and I think someone might have mentioned it above…
If you accidentally click on the black PSA logo, you go to the main site, and there’s no navigation back to the forum.
Yes, the back button works, but if someone is on the main site, there’s no link to the forum or other similar “family” sections.
If you scroll down far enough, there is a link to the forum. (Chrome on Android phone)
As was mentioned the navigation for everything not product related has moved to the footer - the bottom of the website. This is somewhat standard on many sites but different than what we’ve done in the past. Let’s see if folks can adjust. The advantage, of course, is that we get to use the cool picture based menu for navigating products. Instead of scrolling through product titles you see the images of the products and can go there easily. That works great for products but not so easy with forums, and informational sections.
gotcha, thanks Paul.
Ok, I figured out a way to pull this off and make it easy for everyone. Go put your mouse over the new menu item up top called Discover. There I’ve fashioned a duplicate group of the most popular places to go including the forums, Paul’s Post, etc. Registration, downloads, manuals and all that remain at the bottom. Let me know what you think and if this helps. I like it better.
Much better Paul…Thanks!
I love the new Discover button. Thanks Paul.
Yes! Thanks :+1:
I used to enjoy this forum, but now I have to wade thru a ton of adds for PSA products to reach the forum. The adds take up half of the page. I may have to check out of this madness.
Have you tried the Brave browser? Best add blocker out there, plus one of the fastest browsers available.
Try the new Discover button.
Well, what do you think one of the primary roles of this website is?
Good idea, not working on iOS/Safari/iPhone yet…
FYI
My pleasure. Great working together. Keep ‘em coming!
The old menu is probably in cache. Safari for sure, just do a shift/refresh and it should appear.
I like the new menu on top of the screen. Your speaker options, for instance, all show up when hovering over the word “Loudspeakers”. This makes it easy. And when on the main PS Audio page, hovering over “Discover” the word “Forums” shows up as an option.
Works great. Can we add these to the discover dropdown?
Discover button best tweak to the website!
I know I am supposed to be cranky all the time but Paul, I am liking the way the forum works these days!
