FS: Absolutely mint NuPrime STA 9 amps (pair) in silver
#1
I’m looking to see if there’s any interest here on the forum for anyone wanting to purchase my twin STA 9 amps in silver.
They’re in mint (like new) shape, are lightly used, running bridged mode powering a pair of small Sonus faber bookshelf speakers in an apartment, so you know these guys are just idling the whole time.
They’re excellent sounding amps, but I may be taking my system in a different direction soon, so these would have to go.
Anyway, I’ve only had them a few months, have all of the original boxes, manuals, etc, etc. I’m looking for $1100 for the pair, plus insured shipping to the lower 48 states.
Please reply here and/or PM me. Many thanks in advance!
#2
Just some specs on these sweet little amps…
  • Inputs:
    • RCA: Un-Balanced input x 1
    • XLR: Balanced input x 1
  • Outputs:
    • Stereo Speaker Out x 1 or
    • Mono Speaker Out x 1
  • Power: 2 X 120W / 1 X 290W @ 8 & 4 Ohms
  • Peak Output Power: 2 X 280W / 1 X 320W @ 8 & 4 Ohms
  • Input Impedance: 47k Ohms
  • Input sensitivity: 232.8mV, 1W @ 8 Ohms; 1.4V to rated power
  • Gain: x 22
  • Signal to Noise Ratio: < -95dB at 1W, 10W, 100W
  • THD+N: 0.02% (Stereo) / 0.01% (Mono)
  • Frequency Response: 10Hz to 50kHz
  • Worldwide AC voltage: (115 VAC / 230 VAC) with Voltage Select Switch
  • AC Fuse: Slow-blow, 3A, 250VAC
  • Dimension: 235 mm W x 281 mm D x 55 mm H (including feet)
  • Weight: 4.75 kg
  • Color: Silver
  • In a 110V outlet, the idle-power consumption is below 14W. In a 230V outlet, the idle-power consumption is below 16W.
#3
New lower price of $1100.
#4
$1050 for the pair…
