New price: $3,000.
For sale Von Schweikert VR35’s with upgraded JPS internal wiring.
Have the original boxes and will ship from Denver zip code 80226. Buyer pays shipping costs.
I am the original owner of these speakers which have resided in a dedicated smoke-free, kid free listening room from day one. They have been very well cared for and are in excellent working and cosmetic condition.
These speakers have provided me years of trouble free musical enjoyment. Selling due to upgrade.
You can check out my 100% positive feedback on Audiogon, user name gme109.
Reviews:
http://enjoythemusic.com/superioraudio/equipment/0711/von_schweikert_vr_35_export_deluxe.htm
"If you do not achieve “goose bumps” when you are listening to the VR-35 Export Deluxe speakers, you have not achieved their full potential " - Enjoy the Music
"Von Schweikert Audio’s VR-35 Export Deluxe is a remarkable loudspeaker. It performed wonderfully, handling all musical genres with aplomb. " - SoundStage!
Specifications :
Frequency Response: 25 Hz to 30 kHz (+/- 3dB) Sensitivity: 90dB/W/m Impedance: 8 Ohms nominal, with a minimum of 5 Ohms @ 25 Hz.
Tweeter: 1" treated fabric dome, Danish-designed Dual Ring design with rear chamber for low resonance and powerful response down to the midrange band, Low Distortion Motor, and custom voice coil/top plate design for low distortion.
Midrange: Two Scan-Design 6" treated paper cast-frame bass-mids with low distortion motors, elevated spiders, copper clad pole pieces, and composite laminated cones using cellulose acetate pulp, plastic resin, and carbon impregnation to eliminate standing waves on the cone surface.
Crossover: First order circuit using “audiophile-grade” parts, with cross points set at 80 Hz and 6 kHz. All crossover parts are made by Mundorf and Erse, with custom solid copper foil capacitors insulated with Teflon dielectric film.
Subwoofer: Scan-Design custom 10" with Low Distortion Motor, laminated composite cone, elevated spider, long throw design, and copper clad pole piece.
Woofer Alignment: Quasi-transmission line design using three chambers, each tuned to a different resonant frequency to extend the bandwidth and reduce “one note bass” typical of ported boxes. Woofer “fires” at rear wall to boost the bass at 20 Hz by 3dB, and can be “tuned” by user.
Power Rating: 35 watts minimum, up to 500 watts on peak music. Dimensions: 50 x 16 x 12 (HxWxD in inches) Weight: 115 lbs.
