markus46 said
… if there is an improvement to be had by isolating network traffic between server and end-point in this way, the reason for the improvement must be due to something other than approaching the limits of available bandwidth?
I can’t say there is an improvement because I’ve never set up my network in any other way. However here is a review of an audio server (MD600) and end-point (MS600) that touches on the audible changes that occur with network complexity. http://www.hifi-advice.com/blog/review/digital-reviews/network-player-reviews/meridian-sooloos-md600-and-ms600/
I’m not sure if your reference to dedicated ethernet cables is a typo, but to be clear - I’m discussing the isolation of network traffic via a dedicated switch.
What else is on the end of that network cable running to my renderer? I’m probably going to fall into a carefully planned logic trap here, but the answer is a GSIO LAN Isolator. And on the end of that device is a 4-port switch.
I’m convinced that changes in sound quality when network connections are changed (or when servers are changed) are a consequence of changes in electrical interference injected into audio equipment through network connections. The sources of interference are many (aerial effects of data cables and PSU cables to network components, induction from other cables and equipment, switched mode power supplies and probably more). So descriptions of changes in sound quality when network topology is changed need not be doubted but equally may be no guide to the effects of network changes in your own setup.
In my reference to a dedicated Ethernet cable I meant an Ethernet cable providing the path between one’s source of music files (music serving computer, NAS, broadband router [for streaming]) and one’s music renderer, but which had no other data traffic on it. For example my setup looks like this…
Home ‘office’: broadband router / WAP / music server / switch (for extra ports – I’ve a lot of kit in that room) > long, single network cable (through walls, etc.) > Lounge: switch / DSjnr / Sonos Connect / smart TV / Blu-Ray player / Apple TV box / WAP
(WAP is WiFi access point. I have one in the home office and one in the lounge for improved coverage.)
That long, single network cable provides all data for all of the devices in the lounge. But as I’m not worried about network bandwidth I’m content with my arrangement. In the context of my setup a dedicated Ethernet cable would mean an extra one between the switch to which my music server’s connected and my DSjnr alone, but my assertion is that I don’t need one and that others need not spend their money on similar.
This is only peripheral to galvanic isolation, though. Whether one were to use a dedicated (as defined above) network cable or a cable for all purposes (my arrangement) there will still be the potential for injection of electrical noise into a DS/jnr through its network cable. And so we’re back to optical isolation or a transformer isolator for that last Ethernet leg.
Peter
