This cable is the personal owner owners of worldwide wholesalers. He stated they have auditioned 450 usb cables and the best they have heard is the Inakustik pure silver at $3500 U.S and then 2nd is the Pink Faun. I think you already have a winner Luca. I’m going to see if he can give me a good deal on there matching Ethernet cable.
I played a few DSD256 files and they sounded better than last week. I added a Master fuse, but the SQ improvement of these files are greater than the PST playback. I believe the logical explanation is the Omega USB cable had more break in (two weeks in system). The hi-resolution music seems particularlly benefit more from it.
Now I am in waymenchen camp, these hi-end digital cables make as much difference as any other type of cables in the system.
Okay, you have convinced me. Cables matter!
The sad thing for me is I have no use for a USB cable in my system. Do they make Omega AES/EBU cables? I suppose I should look. My Stealth AES/EBU cable was not cheap. Can you return them if they don’t please you? Is that even possible?
Before Stealth I was all about Shunyata. I am not actually sure the Stealth top USB betters the lowly Sigma. I would pick one at random and be happy with whatever I got.
Omega. Have you compared it to the current tip top trendy cable, the Dragon? I haven’t Dragoned yet.
Luckily USB is all I could use from Omega, their aes/ebu is at higher price ($4,750). It is still a bit lower than Stealth top line, I think.
By $1200. I think I will take the it’s already paid for and move on not knowing route.
From reviewing a few top USB cables, I know I would be happy with any of them. You already reach the top of mountain, and all you get is a different view when turning your head. The views are all good!
