Holo Red I2s set up for Stellar Dac
Can anyone tell me how to set the switches on the Holo Red for the Stellar DAC? I read the manual and some posts but don’t clearly see how to set the 4 switches, which on or off? Thanks.
Welcome!
Based on memory it should be Alt. 2.
Thanks. But what are settings for Alt2?
Thanks!!! And could you tell me what each of the 4 switch settings are for Alt2?
1 is off and 2 is on. If streaming DSD then 3 and 4 are on.
Thanks you!!! And I assume if PCM then 3 and 4 are off. Again I really appreciate your help.
Sorry for added question as I see you answered it in your prior mail. Thanks again.
