I2S Digital Input on DirectStream
#1
Can you connect the HDMI output of a cable tv box and input it to the I2S digital input of the DAC? If so, what type of HDMI wire is required? I have be using the Toslink output of the cable TV box to my current DAC which I hope to replace with the PSAudio DAC.
Thanks.
#2
yyz said Can you connect the HDMI output of a cable tv box and input it to the I2S digital input of the DAC? If so, what type of HDMI wire is required? I have be using the Toslink output of the cable TV box to my current DAC which I hope to replace with the PSAudio DAC.
Thanks.
Sorry yyz, the HDMI input is for i2s digital data only, it doesn’t work for standard HDMI audio and video protocols like those from a cable TV box.
