@galen-gareis @rower30 I use Belden 1313A at your recommendation for my speaker cables. What do you recommend for in wall cable if I’m still going to use the 1313A from wall to speakers?
AFAIK, 1313A isn’t approved for in wall on a new build.
1313A is UL 1666 CMR rated for horizontal or riser locations, both. It can’t be used in AIR PLENUMS.
1313A can be used virtually anywhere you need it to go in walls or riser spaces outside of inside air handling ducts and plenums.
Best,
Galen
(Attachment 1313A_techdata.pdf is missing)
