Hello community,
I am looking into Paul’s advice to install a separate circuit breaker to feed my DAC. Does anyone have any recommendations for particular gear to use? Like cables, wall sockets, perhaps even circuit breakers (is there a difference?)
For my own system I use AudioQuest cables (Tornado) but purchasing 20m of AQ cable to connect the circuit breaker to the wall socket is insane, both ridiculously expensive and difficult to install (horrors beyond imagination, I assume).
What works well? What AWG (mm2 in my country) should I be looking for? Silver-plated? Gold-plated contacts? Is the alpha treament of Furutech worth anything? Gold-plates circuit breakers (if they exist)??
Would appreciate any advice you have!
Best regards,
Gavin
