Intel pro 1000 pt dual & DirectStream DAC bridge
http://www.psaudio.com/forum/directstream-all-about-it/intel-pro-1000-pt-dual-directstream-dac-bridge/
Sorry for the duplicate
I have a some problem!
I connect DirectStream DAC bridge to this card (intel pro 1000 pt dual) ! This card have two lan ethernet connectors! But Link is Down!
OS – Linux! Linux ubuntu 3.11.0-26
I try to
ethtool -K p1p2 gso off gro off tso off
Dont help!
Also set limit to 100mb half dumplex
ethtool -s p1p2 speed 100 duplex half autoneg off
Dont help!
[ 2493.399455] lan: port 2(p1p2) entered learning state
[ 2508.434031] lan: port 2(p1p2) entered forwarding state
[ 2530.194268] e1000e: p1p2 NIC Link is Down
[ 2530.194360] lan: port 2(p1p2) entered disabled state
[ 2544.265940] e1000e: p1p2 NIC Link is Up 100 Mbps Full Duplex, Flow Control: None
[ 2544.266057] e1000e 0000:01:00.1 p1p2: 10/100 speed: disabling TSO
[ 2544.266108] lan: port 2(p1p2) entered listening state
[ 2544.266126] lan: port 2(p1p2) entered listening state
[ 2559.295594] lan: port 2(p1p2) entered learning state
[ 2574.330184] lan: port 2(p1p2) entered forwarding state
[ 2596.370308] e1000e: p1p2 NIC Link is Down
[ 2596.370403] lan: port 2(p1p2) entered disabled state
[ 2610.509970] e1000e: p1p2 NIC Link is Up 100 Mbps Full Duplex, Flow Control: None
[ 2610.510087] e1000e 0000:01:00.1 p1p2: 10/100 speed: disabling TSO
[ 2610.510138] lan: port 2(p1p2) entered listening state
[ 2610.510157] lan: port 2(p1p2) entered listening state
[ 2625.511646] lan: port 2(p1p2) entered learning state
[ 2640.546224] lan: port 2(p1p2) entered forwarding state
[ 2665.333352] e1000e: p1p2 NIC Link is Down
[ 2665.333442] lan: port 2(p1p2) entered disabled state
[ 2679.477013] e1000e: p1p2 NIC Link is Up 100 Mbps Full Duplex, Flow Control: None
[ 2679.477129] e1000e 0000:01:00.1 p1p2: 10/100 speed: disabling TSO
[ 2679.477188] lan: port 2(p1p2) entered listening state
[ 2679.477209] lan: port 2(p1p2) entered listening state
[ 2694.478690] lan: port 2(p1p2) entered learning state
[ 2701.860148] e1000e: p1p2 NIC Link is Down
The strange thing is that this network card with another similar device works fine!But with the bridge – no!
Can something advise? Are there any special features for Intel network cards and PS Audio bridge ?
Thank you!
If you are not connecting to a router/switch, you need a crossover cable to connect directly to the bridge.
Dennis
