Hi
I purchased a factory refurbished BHK 250 with PWA-A9-9H0109 serial number.
It tends to get warmer in one side on the heat sink more than the other side.
Is this acceptable or is there something wrong with the unit?
Kindly advise.
Regards
Nanda
Hi
Kindly advise.
Regards
Nanda
I have the BHK monoblocks, but I can say that they are definitely warm even when in inactive sleep mode. I believe the stereo BHK 250 has a heat sink on each side, so if you mean the heatsink on one side is warm and the heat sink on the other side is noticeably cooler, that does not sound normal to me and you might want to ask Delia about it.
Just checked my BHK 250 that’s been on and playing music for the last two hours and both right and left heat sinks feel the same temp wise.
Yes don’t know why that on my unit one side is different from the other.
Yes I don’t know if it is a internal issue or a tube issue.
About the tubes, try swapping the pairs tubes from one channel to the other. If they are the problem the heat issue will also move to the other channel.
I did that, it’s the same heatsinks get warmer on one side the left side. I read in the forum on BHK, that this issue existed when the amp was New, however they identified the problem and rectified it, and all units thereafter was sold with the said modifications. Am puzzled about this.
Are the heatsinks warmer in the back where the tubes are than in the front on the left side? Also is this inequality the same when the amp is in standby vs powered on?
No, the heatsinks on the left get warm from the bottom and spread upwards. Yes is there during standby mode as well.
Serial numbers A9 are well into the production lifecycle (probably around 2019) so there won’t be any early changes that won’t be in it. They could have changed boards and put much later boards in.
I have two BHK250s and they warm up totally differently, one draws much more power for a few minutes than the other.
If there’s some resistance in speaker leads then that could cause extra heat so try swapping the speaker leads over (I once had a dodgy speaker lead).
Edit made to correct 2009 to 2019.
Yes , I read that the changes were made when issues about heatsinks getting hot were raised, I went back to the older chats and saw this. Will swap to a different set of cables.
did you check with the temperature gun, If one of your friend is in Construction or in Medicare maybe you could share one with you
Point that heatsink, And read the number!
No have not done that, but for sure when you touch one side you can feel that it’s warmer than the other side. Will try to get hold of one
Knowing the temperature difference is a nice to do, but it is time to contact the mothership for professional insights. Something is not right.
Have emailed them , waiting for their reply.
