Jumping from an older firmware to the latest
Are we installing updates or complete firmware data. I ask this because so many people say “upgrade” and if that’s the case then should I not install all of the “updates” in order of release so as to not leave out what may be left behind from a previous version? when I received my direct stream it had yale installed. I went straight to redcloud. Should I have install torreys then huron before installing redcloud? What do you think?
Each version is complete in itself. They are not incremental upgrades, so you are fine.
Thanks, that’s what I figured
