LanRover and Windows 10
I am setting up to sell my LanRover, which I haven’t used for maybe 16 months, and saw the notice on its (discontinued) page that it doesn’t work with computers running Windows 10. Since I used it with Win 10, is that incompatibility something which developed with later versions? What was the problem? Thanks,
Just compatibility issues. If you had it running you’re in a better spot than some. It could be used but usually took some finging with computer knowledge.
