Latest Torrey
Mines say Torrey 1.8.8
Each software release is a set of files that should all be used together - the version numbers on the screen for Torreys should be:
Bootloader: 1.13
Firmware: 1.8.8
Bridge: 0.0.0
FPGA: 0.112
USB: 00.33
Rev: 0137
(The 0.0.0 for the bridge is a bug in the display of the Bridge version number.)
That is the same as mine…
Bootloader: 1.13
Firmware: 1.8.8
Bridge: 0.0.0
FPGA: 0.112
USB: 00.33
Rev: 0137
so then mine is current. Sweet. See you guys in LA at the LA Audio Show… June?
Hi Dave - I’m not sure I’ll be at LA personally, I will be at RMAF: I hope to see you and your wife there.
