Agree, it is not something that you setup and forget about. But, it does deliver.
Hi There - Has anyone had an issue with Muon Pro Ethernet filter slowing network speed? I sensed something was not right - did some testing and when I insert my Muon Pro speed goes from 1Gb to 90 Mbps…very weird. I also have a little inexpensive Ifi Filter and it does not do that…I have a message into Network Acoustics. Just wondered if Anyone tested speed with this? Thanks…
As happy as I am with the SW6, I think I’ll be ordering a Tempus after all. I was a little afraid things might get too incisive/analytical with the Tempus, but a few developments have eased that concern: the PowerZone has broken in nicely, I warmed up my room acoustics with a full complement of StillPoints Aperture panels, and I’ve started experimenting with racks which have further balanced/improved things. I suppose I may as well order a Muon Pro while I’m at it…
If you find you enjoy the benefits of the Tempus, that may push my hand.
When is enough enough??? LOL
we are all hopeless sheep
That’s the spirit why let up?… momentum is on your side!!
We have introduced you to Sean already, correct? If not, PM me. He can get you both the Tempus and the Muon, and the Stealth Audio Ethernet cable that slays the MUON cable.
(Or so I have read)
Slay is a strong word. Better yes.
I broke from my rule that you have to hear it first before you buy it on this one. Both you and Luca liked the Stealth over the Muon so I took the plunge.
Blind faith I guess.
so are y’all saying I should get the Black Magic instead of the MUON?
I’ve used both in my system now I use the Stealth black magic. The Stealth has a natural sound and seems to extract more details then the muon USB cable imo.
The top notch Ethernet STEALTH ULTRA of course, the most expensive one!
wiat, what? can listen to an Innuos server from different locations?
I have multiple homes, two of which have their own INNuos server. Easier than moving my CD collection from location to location.
Thanks @Justrucking Michael
I noticed that the 12V batteries discharge in 2 hours and will inevitably worsen with time. I could easily have music running for longer so that could make or break for others I assume…
I routinely play for up to 8 hours without issues. Then the batteries, when or if they fail, I can get them locally. Also, it will charge and discharge simultaneously with no noticeable affect on the sound.
That sounds promising! Hmmm, now you’ve got me tempted! Thanks
Well, I just installed the LHY USB Isolation UIP Decrapifier, and am incredibly impressed! I also added another 10 mhz clock to the mix, so I now have clocks on both the ethernet and the USB direct to my DAC.
Here is the LHY unit… https://www.aliexpress.us/item/3256807730068711.html?spm=a2g0o.order_list.order_list_main.23.7c7918027GDMBx&gatewayAdapt=glo2usa
Here is the clock with GPS antenna, I own two, and they work. Much less expensive then the audiophile clocks and they get the job done. I also have a capacitor bank in-between the LPS and the clocks… https://www.aliexpress.us/item/3256802943951872.html?spm=a2g0o.order_list.order_list_main.46.7c7918027GDMBx&gatewayAdapt=glo2usa
Here is the power supply for the clock… https://www.aliexpress.us/item/2251832699357038.html?spm=a2g0o.order_list.order_list_main.29.7c7918027GDMBx&gatewayAdapt=glo2usa
Here is the Ethernet unit, using the above clock… https://www.aliexpress.us/item/3256807741335925.html?spm=a2g0o.order_list.order_list_main.40.7c7918027GDMBx&gatewayAdapt=glo2usa
And the Ethernet isolation unit that feeds my streamer… https://www.aliexpress.us/item/3256807745262486.html?spm=a2g0o.order_list.order_list_main.41.7c7918027GDMBx&gatewayAdapt=glo2usa
Here is the capacitor bank I mentioned above… https://www.aliexpress.us/item/3256807556026617.html?spm=a2g0o.order_list.order_list_main.34.7c7918027GDMBx&gatewayAdapt=glo2usa
Do not discount this gear, it is not snake oil, and in my humble opinion, is well worth the cost. I am using the Roon Nucleus One with the Farad Super 3 LPS, and of course another capacitor bank to the Volumio Rivo streamer. And many upgrades on the network feeding the Rivo. Every little detail matters. And I cannot say enough about this ToneWinner AD- 1PRE+ DAC/Preamp. The DAC in this thing via USB is simply incredible to my ear. It is a cross between an R2R and Chip DAC, I have no clue what these guys did, but they did it right. And I have had more than a few DACs through here, a couple of PS Audio Units too… This DAC simply nails it. My PS Audio Stellar Gaincell is second to this ToneWinner DAC.
Here is the ToneWinner DAC/Pre… TW AD-1PRE+ Amplifier – SUMMITHIFI-USA
The amp is the D5 Pro, this amp is simply incredible for $600 delivered… https://www.aliexpress.us/item/3256806124599982.html?spm=a2g0o.order_list.order_list_main.98.7c7918027GDMBx&gatewayAdapt=glo2usa
The Cary clone preamp/tube buffer, game changer for $320 delivered… https://www.aliexpress.us/item/3256806156599319.html?spm=a2g0o.order_list.order_list_main.103.7c7918027GDMBx&gatewayAdapt=glo2usa
Speakers are the Cabasse Murano bookshelves… Murano - An exceptional compact bookshelf speaker from Cabasse
We are sitting here listening to Satin Doll by McCoy Tyner and the piano is so clear, you can hear the strings at times. And the beauty is, none of the sound is hard or hyper detailed, just so pleasing to the ear. Very happy!
I recently bought two 245Wh portable power stations, feeding my streamer and LNY switches. Didn’t expect much, but pleasantly surprised. The brand I’ve bought is EcoFlow. YMMV
I received my LHY USB Purifier the other day, and another 10 mhz clock with the ZeroZone LPS, and am very impressed with the increase in clarity. I have my tracks that I listen to for testing, Miles Davis is my go to. Prior to the LHY USB unit, I thought things were incredibly good, not so. The introduction of the LHY unit was a good 10% increase in overall SQ. The speakers are the Cabasse Murano bookshelves. Worth a look.
