Actually I think this is a very interesting idea. EMI is a FACT that nobody can deny! I think it’s quite commonly known that most ordinary UPS’s power is noisy/dirty. The Quintet may be a fairly entry-level device - but it IS designed to filter and isolate electrical noise.
However, to me, the bigger question is where do I stop? And by this I mean in the steps to upgrade my power. Sadly I’ve had to get rid of my P20 because of it’s inability to drive my Aurender AP20 and blowing the Aurender NH10 Network Hub’s fuse! So I got a relatively entry-level Transparent PowerWave X Line Conditioner. It should be way above (say) the Quintet (no disrespect, it’s a good product). But it can’t do what the P20 did. No ways am I going to move into Stromtank S-5500 HP, or Gryphon PowerZone territory!
So my feeling is: This is where I stop. Not going to feed my next-door router or NAS or computers with dedicated power cables; Not going to hang EMI-Proof special curtains and so on.
On the other hand, my own Post Scriptum:
What if one can MEASURE results? As you’ve shown! Now it becomes EASY to check:
Does this power cable vs that one really measure differently?
And this power amp; DAC or streamer vs that one?
How far should I go with Line Conditioning?
How much difference do I get if I switch off equipment in other rooms when I do critical listening?
Your idea with a Line EMI monitor (if one can trust the readings) I think is a GREAT one. I’d certainly rather explore this, than to “run in” cryogenically treated fuses!
Edit: It occurs to me that the best way to use that device (with a Quintet or similar) is to have it plugged into one of it’s “isozones” (or similar)? That way one should be able to see the difference (if any) when switching on kitchen lights, or hi-fi components for that matter.
The Schnerzinger Grid Protector is an item I bought to remove EMI and similar pests from my listening room. It does it’s job well.
It probably cost above $6K now. It is also highly recommended that another $6K Schnerzinger product be used with it. I think it may be called an LAN Protector. I didn’t try it. Others did and bought over $35K worth of other Schnerzinger Snake Oil products.
Tread carefully down this rabbit hole. I did.
When I first installed it I set it to Maximum Power. (all three switches set to 11) The black level in my room went to a new and deeper black level. It is astonishing to say the least. You don’t have one in your room??!! Why bother even having an Audio System? Get a Boombox and stop there!!
Warning, these two websites require a Masters Degree level of reading comprehension.
Well, I just did that, let it plug since 21 on the speaker is barely audible, but unplug it for the night.
This morning, it was a cold morning and, first thing, I plug in the wall
30 seconds later, noisy as crazy, the speaker was gzggggaaaaggzzzzz, I look at 2256! wow! what is running in the house! Heat pump 1, nope it is Ok, heat pump 2 yike!!!, that’s the noisy one!
Now, where do I stop, that what I discuss with my musician son! and now it affect less my music room than the rest and strangely as it is, some part of the house are dead quiet and others goes sky roof with noise floor, why I don’t know! but I imagine the face of my electrician when I will explain this to him and ask to resolved that!
I intend to order 2 or 3, to do some test at different time of the day on different circuit! 500$ for the 3 on Ali-X and help pinpoint noisy component or device in the house! (they also sell one for radioactivity to check my FM signal! )
And no, I don’t have a microwave and house is in brick thick brick no cell work inside, we have to use internet! so very RFI shield!
Where will I stop, I don’t know, but fun to investigate and reward on sound impressive!
By the way, measuring without power bar, and with power bar, made me realize that those device have an impact!
Also with the power bar on, It help identify the power line in the house, so everything connected in the wall, the power bar have also an decreasing noise impact on that line!
