If you are beta testing the Stellar Gain Cell DAC and have a DMP, you’ll want to install this latest DMP update so Stellar can communicate with DMP and playback DSD.
Paul McGowan said
Download the files, unzip it, place the contents inside the folder on an SD card, and update DMP.
With most PSA products, the firmware update files go at the root level of the SD card; if they are in a folder, they are not read. Is the DMP different?
Ambiguity:
Download the files, unzip it, place the contents [which are] inside the [source] folder on[to] an SD card, and update DMP.
vs.
Download the files, unzip it, place [those] contents inside the folder [which is] on an SD card, and update DMP.
