NPC USB Connection Issues?
#1
Hi Folks,
When I turn my computer on for a new recording session, the PS Audio NuWave Phone Converter is not initially detected by my computer, a Sony VAIO laptop. In order to get it to work, I have to either 1) cycle the power of the NPC or 2) disable and then re-enable the USB function from the NPC front panel?
Is this normal operation or is there something I need to check in either the computer’s setup or the NPC’s configuration?
Thanks much!
Joe
#2
This is a known issue we are exploring way to fix it.
Dennis
#3
Sounds good! No biggie.
