Nuwave DAC, Output Connection Questions
Hi Folks, I have the balanced outputs of the Nuwave going to my preamp. My question is, can I also connect the unbalanced outs to my Definitive Tech. sub inputs without causing problems? Also, can I use a Y adapter at sub end and connect to just one of the subs inputs?
I don’t want to affect the balanced outs of the Nuwave to the preamp.
Many Thanks, Niel
Hi Niel,
You can connect your Sub to the Left, single ended output of the NuWave. This is a standard method and will not affect the balanced output from the NuWave DAC to your preamp. Hope this is helpful.
Thanks,
  • Jeremy
Thanks Jeremy, I didn’t want to let any of the smoke out.
