Obsessive turntable isolation question
When I designed my listening room, I had read that isolating my turntable from the sound coming out of my speakers would be ideal. So I set up my turntable in my media room and ran the interconnect, and ground wire through the double-wall to connect to my pre-amp. The wall I affixed my Pangea turntable shelf to is load-bearing and everything is on a concrete slab, and since its wall is outside the wall facing into the room, there’s no sound transfer there. It became a pain in the butt to drop the needle, scramble into the media room, shut the door, then turn up the volume, usually missing the first 5 seconds of music, so I rigged up a remote switch, so I can put the needle into the run-in with the TT off, go into the room, then flip the switch to start things up.
What I’m wondering is whether this is a bunch of nonsense, that why could I not just have the turntable on the top of my audio rack in my listening room? My vinyl rig is probably in the lower middle of the audiophile range (TT + cartridge about $1500), I do about 10 times more digital than vinyl, and my audio rack is decent quality, has the sharp isolation feet on a concrete floor. I’m thinking the only possible “air” transfer of sound from speaker-to-cartridge is the fact that my room is fairly small (13 x 10) and the subwoofer is only about 3 feet from the audio rack.
Do you think I would be plenty safe when it comes to sound isolation? Or since I already have it set up in the outer room, keep it that way? And heck, very little of what I listen to - acoustic and jazz at reasonable volume - is going to shock things anyway.
great question! and no, going to extremes is not nonsense, but it is costly and inconvenient, or in other words “audiophile activities.” I took a different approach: I built my own rack using solid 3/4" copper rods for support and thick baltic birch shelves with the TT sitting on a hollowed out 4 inch thick wood shelf filled with lead buckshot and mineral oil as a dampener. It passes the tap test - taping sharply on the TT shelf while playing a record an having zero sound passing through to the speakers.
But, now that you mention it, I can do better. Remote location of the TT is likely the only way to isolate it from ALL vibrations being produced in the listening space. Hmmm.
Oooooh, sorry for introducing what could be an expensive subject! But it does sound like when it comes to the LEVEL of turntable seriousness, you have me beat. I’m not even doing MC - I compromised with a Grado MI (moving iron) cartridge, which is lower mass than MM, but a bit higher output which my phono pre-amp likes.
So if you built your own solid rack and can tap on it with no noticeable sound, my guess is it is doing a good job of not transferring any sound in the air to your cartridge, but what do I know? Are you on a wooden or concrete floor?
Expensive subject? Isn’t that what this forum is for? :slight_smile:
I’m on the second floor with solid hardwood. Footfall isn’t too bad, but the suspended floor does resonate. I’m using an MC cart. I had thought of installing Stack Audio Auva 100’s on the feet of the rack, but then why do that when I could dig down to bedrock and move my listening room there?
I found great isolation for my turntable, on top of my audio rack (Samson Version 3 from Mapleshade) by using s PS Audio PowerBase and on top of that using Stack Audio isolation feed under my turntable. It seems immune to sound and vibration in the environment. And noticeably better sound overall. (I have a Rega RP3 with all Groovetracer mods, the new white belt, an Exact2 and the NEO2 motor control).
“Obsessive” yes.
Notice where the turntable is relative to the speakers. No noise, feedback, complaints.
Don’t believe every “expert”.
Why not just move the table and see what it sounds like?
I am definitely in the “obsessive turntable isolation” category. My vinyl rig is all Rega as listed below.
TT = Naia; Cart = Aphelion 2; Phono pre = Aura; Rega wall shelf modified with walnut plywood to support below platform.
I have spent many hours (years?) trying to optimize this isolation with varying degrees of success, but never felt the issue was completely solved. Louder bass especially could lead to some acoustic feedback that caused either muddiness or worse sustained positive feedback with growing amplitude! Even with the wall shelf I could clearly hear foot falls, etc.
I finally settled on a very expensive but very effective solution that is clearly audible and improves sound quality in my quite revealing system.
A company called Minus-K makes a range of “negative stiffness” totally passive platforms for scientific equipment like SEMs (scanning electron microscopes) and other devices that are very sensitive to vibration from building movement, HVAC, etc. They also supply a custom version of this type of platform for SAT (Swedish Audio Technology) and their (I am not making this up) $380,000 turntable.
The smallest unit with up to 11 lb. capacity worked great with my lightweight TT.
+1
A nice hardwood or mechanically engineered platform, isolation footers of your liking. Good to go…
Best,
JP
A friend tried a Stack Audio isolation platform under his VPI HW40 and he can’t stop babbling about how great it is. (Surprising since he’s one of the “everything is snake oil” types)
Absolutely nothing wrong with obsession (anything); as long as it doesn’t interfere with Enjoying Life; and harming anything or anybody.
Seems like moving the turntable into the listening room to see what happens is a very easy and inexpensive thing to do.
But difficult and expensive is what we love about this hobby, right? :slight_smile:
I’m a big fan of a wall mounted shelf for my turntable. Mine is a DIY setup with Home Depot parts. Two L brackets firmly attached to studs in a weight bearing wall in my music room supporting a well made shelf worked well. My SOTA Nova turntable used to skip all over the place when I walked across my bouncy floor. Even with a suspended sub chasis, the Nova couldn’t handle footsteps. But now, it could withstand a small earthquake. It was an inexpensive fix and worth the effort.
If someone really wants the ultimate solution, I have an extra Halcyonics type electron microscope active vibration modular platform I’d consider selling. Even when the power is off it helps, but when the power comes on its like the LP sound becomes more focused, exactly like what it does for a scanning electron microscopes.
@emailists , platform size and weight limit, please?
@JLawry I don’t think your needle will pick up sound from your room, especially when you’re playing a record. I have a small room and don’t have that problem. What I do have is an old house with old wood floors. If you’re looking for a cost-effective DIY solution, you can make a highly effective isolation platform with a piece of wood (I used high density MDF), and a set of 4 Visetek microscope isolation feet from eBay. Not their audio ones branded as Aurios, but the actual microscope isolation feet. They pop up on eBay from time to time with the microscope platform, but those are sought after and expensive. I got a set of four feet sans the microscope platform for under $55, then some bolts, nuts, and washers from Lowe’s to bolt the feet to the platform wood. The bolts that come with the feet are designed for the microscope-specific platform and aren’t helpful here. To get my turntable to skip now, I have to stand by it and aggressively jump up and down.
Oh, you people who tell me to use my ears just don’t get it :winking_face_with_tongue:. Seriously, you’re right, but I also know that my ears are not always as good as others around here - heck, I might be able to put my turntable IN FRONT of my subwoofer and not be able to hear a difference. A lot of this stuff is theoretical first and hearable second.
So you’re saying you have your turntable in your room, on a basic rack, and it’s isolated enough to not hear any problems? Or is it because it’s back in a recessed area, that it’s not getting vibration from the room?
After reading these replies, I’m combining them into a few common themes:
  • Whether my room is on a ground-level concrete slab or a suspended wood floor is probably the biggest concern - I can disregard this one because I’m on concrete (music concrete?)
  • For those on floors not on the ground, there are a range of ways to minimize transfer of sound from floor to table, from DIY to electron-microscope anti-vibration systems
  • Although it hasn’t been mentioned, if you’re going to mount to a wall, if possible you should mount to an exterior wall or a load-bearing wall that is built in contact with the ground. Some vibration might still be transferrable from floor to wall to table, but not nearly as much
  • Beyond that, it is unlikely that I would pick up much, if any, noticeable “through the air” vibration caused by the speakers being in the same room with the table
  • However, I can make more sure that any “in-air” sound is not affecting things by using some of the same methods used for minimizing “from-floor” vibrations
I think what I’m going to do is nothing. Still a bit of a pain to have my turntable in a separate room, but I think that is the best overall scenario for no vibration at all. I think it would be more likely that I’d get vibration through the earth to my concrete floor than from my room. Hate having to complain to the Chinese about their thumpa-thumpa funk music. But better than being below the vibration…
