Optimal Volume Settings
Hi all,
For the BHK Pre and the DS DAC Snr are there any optimal volume settings? I ask as some components recommend volumes ‘past 11 o’clock’ etc for better SQ.
Thanks!
Lots of discussion about this elsewhere in the forum.
You might want to do some searching with key words “DAC volume” “BHK volume” etc.
Some pretty insightful information is to be had.
Quick hit: Ted (IIRC) and other like “84” for the Sr. (I think with the volume attenuation set to off.)
Good luck.
Exactly what I was looking for - thanks!
A post was merged into an existing topic: What Are You Spinning Right Now? (Mk. 2)
I guess this only counts until the next mountain top deploys.
