P10 Base Plate
I have a new P10 power plant on the way. I have three Nordost Sort Kones that I’d like to set it on. My question: This is a heavy, heavy unit. Will the base plate thickness support placing the entire unit on three “points” without distorting it?
Thanks
Cincy
Welcome, Cincy!
I expect it to be fine, especially if you place the cones more toward the edges/corners than the center. The PowerPlants are robustly constructed. Others are using Stillpoints and other vibration treatments without issue.
Paul will likely see this and comment as well.
It should be fine. The base plate of the P10 is plenty stout.
